dontpannic
Xenon advice
Hi All
I currently have coded Xenons in my car which work fine and a huge upgrade over halogen, however I was offered a cheap pair of slightly damaged Bi-Xenon AL headlamps. I'm wondering whether to install the Bi-Xenon projectors over the single projectors (wiring isn't an issue for me) - however the shrouds are damaged (metal worn off).
Where can I get replacement shrouds that fit the Bi-Xenon 3" projectors? Ideally in the UK? Other thought is just to spray the shrouds and the interior vanity panels matt black instead.
Thoughts? Are the Bi-Xenon projectors a better output than the single Xenons?
Even if I don't put these into my car at least I can build up a second pair of headlights for my mate or for sale.
Cheers
Nick
No difference in output AFAIK..
The only difference is when you push the stalk away you get full beams. There's just a mechanical lever inside the housing that moves away. Output is the same.
Info:
http://www.e46fanatics.com/forum/showthread.php?t=159664
I have BiXenon and can't say I use it very often.
Oh I know how the Bi-Xenon works, don't worry about that. Any ideas on shrouds or just go with matt black (seems easiest - especially as the only shrouds I can find are 'universal fit' based on the E46 shrouds).
So with Bi-Xenon, you don't use the halogen full beam bulb at all? Or is it pull lever back for bi-xenon shutter and push away for halogen full beam?
What I mean is - they're not worth the upgrade IMO if you already have the normal Xenons..
Pull towards you and you get the usual low level Xenon and the inner halogen lights on full beam (so just the inners, as in "flash to pass"). Push away you get the inner halogen lights and also the full Xenon beam (so all 4 lights on full beam, but wont self-cancel until you pull the stalk back to the normal position).
With normal Xenons you wont get the full Xenon beam. You'll just get the halogens on full beam.
As I say - not worth it IMO. Up to you though if you think you'll use that extra feature.
You can code it so that:
flash to pass is: halogen only. Or halogen and bixenon
full beam is: halogen and bixenon, or just bixenon
Do you know if you can code it so that flash to pass is Xenon only?
I'd prefer that.. lol
Yeah I've seen the coding options. That was just curiosity really, I'm now just thinking about embarking on a little side project to build a pair of Bi-Xenon lamps from the damaged ones I have (bowls are fine).
Any ideas on shrouds guys, or just go with matt black to match the vanity panel?
I think matt black could work well. Are the singles smaller projectors then?
momo, no, I don't think you can. I don't think it's clever enough to work out if the dipped beams are off (if so, just bixenons would have no visible flash).
Singles are 2.5", Bi-Xenon are 3". I'll go matt black and see what happens, I can't see it looking too bad to be honest.
EDIT: Would certainly look better than insane light bleed from the shrouds where the metal has worn away.
Edited by dontpannic
