hurricane Posted March 10, 2014 Report Share Posted March 10, 2014 For the past week or two, my ABS light, brakelight and traction control light have been coming on every so often, leaving the driving like it was almost in limp mode. Anyway just left the house an hour ago and as I got half a mile down the road, the car started accelerating, as I dipped the clutch it hit the redline. I turned the car of, freewheeled for a while, started the car again and it hit the redline. Car is now awaiting towing. Has the engine just blew? cheers Link to comment Share on other sites More sharing options...
Trevor Posted March 10, 2014 Report Share Posted March 10, 2014 Sounds like its just stuck on full throttle. Link to comment Share on other sites More sharing options...
hurricane Posted March 10, 2014 Author Report Share Posted March 10, 2014 My first thought was turbo but no smoke. What happening? Link to comment Share on other sites More sharing options...
Chimp Choker Posted March 10, 2014 Report Share Posted March 10, 2014 Sounds like a stuck throttle sent with tapatalk pro that mr feva can't use Link to comment Share on other sites More sharing options...
Greg320d Posted March 10, 2014 Report Share Posted March 10, 2014 What engine do you have? Link to comment Share on other sites More sharing options...
BmEagle Posted March 10, 2014 Report Share Posted March 10, 2014 Profile says 320d. Link to comment Share on other sites More sharing options...
Greg320d Posted March 10, 2014 Report Share Posted March 10, 2014 Perhaps the throttle pedal has failed? Link to comment Share on other sites More sharing options...
hurricane Posted March 11, 2014 Author Report Share Posted March 11, 2014 Cars on the computer now, will post fault codes shortly Link to comment Share on other sites More sharing options...
hurricane Posted March 11, 2014 Author Report Share Posted March 11, 2014 Ok men. I am getting 8 - glow plug module control unit 1B - Extra heater 65 - Charge air pressure control 6 - EGR So the last two look like they could be my problem. Any ideas where to go from here chaps? Link to comment Share on other sites More sharing options...
chocka Posted March 11, 2014 Report Share Posted March 11, 2014 First thought is that it sounds like it is eating its own engine oil as fuel but if this was the case you wouldn't have been able to turn the engine off until it ran out of oil. Don't know what controls the fuel on a diesel as it is not like a petrol. Nimraynn 1 Link to comment Share on other sites More sharing options...
Nimraynn Posted March 11, 2014 Report Share Posted March 11, 2014 First thought is that it sounds like it is eating its own engine oil as fuel but if this was the case you wouldn't have been able to turn the engine off until it ran out of oil. Don't know what controls the fuel on a diesel as it is not like a petrol. I was about to suggest a diesel engine run away as well, but you're right, it would just keep running until it either ran out, burned out or you managed to stall it. Link to comment Share on other sites More sharing options...
hurricane Posted March 11, 2014 Author Report Share Posted March 11, 2014 So what you chaps reckon. I gave the EGR a good clean out last year, have done 15k in it since. I will take it of and give it a good clean. I know the EGR cooler is pretty blocked but hard to clean. Charge air pressure control - Anyone know what this is? cheers Link to comment Share on other sites More sharing options...
chocka Posted March 11, 2014 Report Share Posted March 11, 2014 MAP sensor in inlet manifold measures the boost pressure, which i presume is charge air pressure? Link to comment Share on other sites More sharing options...
Scottfreee3 Posted March 11, 2014 Report Share Posted March 11, 2014 I can't remember but on the 136bhp engine if the ecu looses signal from a sensor it removes the limiter and redlines to 6500rpm. My memory is saying a cam sensor....if you want I'll find out. Link to comment Share on other sites More sharing options...
hurricane Posted March 13, 2014 Author Report Share Posted March 13, 2014 Yes find out for me mate. Whats the chances that the car has ingested a broken swirlflap? Link to comment Share on other sites More sharing options...
arry Posted March 13, 2014 Report Share Posted March 13, 2014 Yes find out for me mate. Whats the chances that the car has ingested a broken swirlflap? Pretty much nil from what you're describing. Andrive 1 Link to comment Share on other sites More sharing options...
simonlpearce Posted March 13, 2014 Report Share Posted March 13, 2014 As above, the engine would have destroyed itself if had ingested a flap at high RPM. Does very much sound like oil, usually from a bust turbo seal. Perhaps pull the intake pipes off to double check if there is any sign of a leak anyway, just to be safe. Link to comment Share on other sites More sharing options...
hurricane Posted March 13, 2014 Author Report Share Posted March 13, 2014 Ok but the car did not smoke at all? So I am thinking how can it be oil? Link to comment Share on other sites More sharing options...
hurricane Posted March 13, 2014 Author Report Share Posted March 13, 2014 Of course I will have a nosy and see, cheers for the advice! What about this? http://workshop-manuals.com/bmw/3_series_e46/320d_m47_tour/2_repair_instructions/13__fuel_system_%28m47%29/62__sensor_for_control_unit/3_ra__replacing_charge-air_pressure_sensor_%28m47%29/ Its matching one of my errors, 65 -charge air pressure control? cheers Link to comment Share on other sites More sharing options...
Scottfreee3 Posted March 13, 2014 Report Share Posted March 13, 2014 If it was oil the car will not turn off. The fact it can turn off by the key means it's a computer problem. I check it out and when the computer has a signal issue with the cam sensor it will revv to 6500 rpm. Way over the limiter. I would check this first. Link to comment Share on other sites More sharing options...
hurricane Posted March 22, 2014 Author Report Share Posted March 22, 2014 If the cam sensor was gone though, surely I would expect the car not to start. It starts perfectly and once I drive it, it starts the uncontrollable revving. I am still no further forward with this guys, Ive took the inlet manifold of and as expect the car is FULL of carbon. Other than that, im not so sure. I have a 320d engine for parts here, from a rover 75. So what does everyone think? Link to comment Share on other sites More sharing options...
Jim27 Posted March 22, 2014 Report Share Posted March 22, 2014 Sounds to me like the throttle butterflies are stuck in the open position. When you turn off the ignition you disable the diesel fuel pump, starving the engine (which is why it stops, whereas with diesel runaway it simply wouldn't). I had a similar situation in my old TVR when a piston disintegrated and a part of the debris managed to get out through the intake valves and wedged the throttle butterfly open (absolutely terrifying finding yourself doing double the speed limit in 30mph traffic, slaloming in between cars and wagons to avoid hitting them). Thing is though, with that situation the high rpm coupled with a compromised piston and imbalanced crank as a result pretty quickly saw a catastrophic mechanical failure (conrod through side of block, exploding engine, etc.). Are the E46s a fly-by-wire throttle or is there a physical accelerator cable? If fly-by-wire throttle then I'm more inclined to think yours is an electrical problem too, or possibly some part of the throttle butterfly assembly breaking/sticking open. Link to comment Share on other sites More sharing options...
TriggerFish Posted March 22, 2014 Report Share Posted March 22, 2014 No throttle body on a d though Link to comment Share on other sites More sharing options...
hurricane Posted March 23, 2014 Author Report Share Posted March 23, 2014 Anyone know?? Link to comment Share on other sites More sharing options...
hurricane Posted March 27, 2014 Author Report Share Posted March 27, 2014 Alright guys, the only thing coming on in the computer now is EGR?? What you guys reckon, valve, cooler or something else? Link to comment Share on other sites More sharing options...
