quackers Posted November 13, 2012 Report Share Posted November 13, 2012 Good thread, thanks all. Against my better judgment I decided to go for a set of Kumho KU39 sports. 225/40/18 front 255/35/18 rear They are still new but initial findings are that the grip seems good in both wet and dry. There is a bit of road noise however (but nowhere near as much as with the Runway set that came off - they were BAD for noise). I'm still experimenting with pressures trying to reduce the noise. Will have to wait for further developments regarding noise/wear to make further comment. Link to comment Share on other sites More sharing options...
Dr T Posted November 13, 2012 Report Share Posted November 13, 2012 (edited) Front: Dunlop Sp Sport 01 Size: 235/40/18 (on an 8" rim, captain sensible or what) Cost: £55 each (Partworn from a trader on the bay) with between 4.3 and 4.6mm (these are £130ish new on camskill) Miles lasted: only a few hundred done on them so far. View: I've just fitted these to the front of my Audi A4 190 quattro and so far i'm very impressed.Its November and i've done a few hundred miles in dry but cold, wet and damp conditions and the grip is very good in all of these, the car is noticeable keen and direct on turn in. They do tramline a bit on uneven surfaces but this could be due to the front wheels being driven as well as the back. They've certainly done a lot to move the balance from understeer (both power on and lift off) to oversteer with i find a lot more natural. Buy Again: Assuming they last a normal amount of miles, yes. Edited November 13, 2012 by Dr T Link to comment Share on other sites More sharing options...
Ruesta Posted January 9, 2013 Report Share Posted January 9, 2013 Just fitted Falken's all round. 225/40/18 front and 255/35/18 rear. They are not the usual 452's though.... I went for the asymmetrical ZIEX ZE-912's as I got a good price. They are so much better than the budget tyres fitted before (not by me) I now have wet grip, its smoother, quieter and just feels so much better. If they go on like this and last fairly well I would definitely buy them again. Well chuffed. Link to comment Share on other sites More sharing options...
L333JSA Posted January 27, 2013 Report Share Posted January 27, 2013 Dunlop SP Sport Maxx - 255/35/18. Not impressed by this so called performance tyre. Straight line grip isn't too bad but the lateral grip is absolutely shocking. Not progressive at all......once its lost traction/grip at any kind of angle it just lets go completely. Also sidewalls are massive and too square/chunky - makes them look like tractor tyres and thats on a 9.5J rim. All in all not happy and probably get them swapped asap. Link to comment Share on other sites More sharing options...
Trevor Posted January 27, 2013 Report Share Posted January 27, 2013 Haida HD921 225/40 18 £206 for a set of 4 fitted and balanced. Another set of budget tyres. Been spot on, road noise is very reasonable, grip both wet and dry is good. I only ever push the car in the dry and these have been spot on, plenty of grip. Not saying they wouldn't be ok if pushed in the wet, just that I haven't tried it. I will defo buy again up to now. Just bought another set of these for my new rims. Best recommendation, repeat business. Link to comment Share on other sites More sharing options...
shafz Posted February 9, 2013 Report Share Posted February 9, 2013 Front & Rear Make: "Sunnys" Size: 235/35/19 fitting to a 8" alloys and tested with stretching it on a 9.5" allloy Cost: Came on the car when i purchased it, was wrapped on 19" M3 rep alloys. Quick internet search and they come in about £60 delivered Miles lasted: not sure as they were already on the car, but slow tread wear View: Dangerous on a RWD car, would be ok for a low bhp FWD car. If the road is slightly wet, back end easily twitches when taking corners.....really lowers your confidence when driving. I changed alloys to a staggered fitment, fitted them to front 8.5" and rear 9.5" (stretched on the rear)....NOT a tyre that likes to be stretched, lost air over 2 days.Rubbish bead Removed from alloys and never fitted again. Definitely would not buy these if i had a choice of budgets Nimraynn and feva 2 Link to comment Share on other sites More sharing options...
G12mox Posted March 14, 2013 Report Share Posted March 14, 2013 Please advise may have been asked a hundred times but upto date info needed Link to comment Share on other sites More sharing options...
bungers Posted March 14, 2013 Report Share Posted March 14, 2013 Whats your budget? Link to comment Share on other sites More sharing options...
Rob- Posted March 14, 2013 Report Share Posted March 14, 2013 If you can afford them get vredestein. If you can't afford them get khumo. If you have big wheels then fit as small a rim diameter as you can. This will make tyres cheaper and put premiums closer to your budget RickyZ and mit 2 Link to comment Share on other sites More sharing options...
MRyan Posted March 14, 2013 Report Share Posted March 14, 2013 Fullruns or Landsails are normally pretty good IMHO. Kidding! Seriously though...dont ever touch those - agreed with Rob, Khumos are normally alright for the price. I found mine to be a bit noisy but they had good levels of grip in both dry & wet conditions (not the last word in handling in the wet, but also not terrible) Jay. 1 Link to comment Share on other sites More sharing options...
DJ Syxx Posted March 14, 2013 Report Share Posted March 14, 2013 Have a look at Matador tyres. They have very good reviews. robocoupe and momo 2 Link to comment Share on other sites More sharing options...
maxis740 Posted March 14, 2013 Report Share Posted March 14, 2013 Falkens are highly recommended.. Link to comment Share on other sites More sharing options...
Jim27 Posted March 14, 2013 Report Share Posted March 14, 2013 Khumo Ecstas are fine. I've just fitted Nankang NS-2s all round and haven't got any complaints, and they were pretty damn good value - £270 for all four corners, 18" staggered fitment Link to comment Share on other sites More sharing options...
john.med Posted March 14, 2013 Report Share Posted March 14, 2013 What size wheels and what's your budget? Factor into the cost of replacing tyres that wear quicker than others too. Link to comment Share on other sites More sharing options...
Chris330 Posted March 14, 2013 Report Share Posted March 14, 2013 Got two 18 inch tyres yesturday 1 front and 1 back fitted for 163 all in. Primwells Link to comment Share on other sites More sharing options...
Mikey Posted March 14, 2013 Report Share Posted March 14, 2013 Have a look at Matador tyres. They have very good reviews. +1. These are made by Continental. Link to comment Share on other sites More sharing options...
L333JSA Posted March 14, 2013 Report Share Posted March 14, 2013 Got two 18 inch tyres yesturday 1 front and 1 back fitted for 163 all in. Primwells I don't think that's anything to be proud of I'm afraid mate........in my experience of them they are shocking! Mikey, sive s, Blair and 2 others 5 Link to comment Share on other sites More sharing options...
sive s Posted March 14, 2013 Report Share Posted March 14, 2013 Like what people have said. kumho and falkens are good. found used sets for cheap. very good thread too. its just your luck mate. also i learnt too stay away from some of these budget tires. had some on the fronts with 19s, grip was not all that even with 4mm thread. fitted falkens with similar thread, damn they grip . Like what people say dont do budget on tires , as thats your only contact with the road . Link to comment Share on other sites More sharing options...
Mike- Posted March 14, 2013 Report Share Posted March 14, 2013 My rears will need replaced soon, bookmarked. Although I don't want tyres that are too grippy, or I won't be able to impress the girls. Jay. 1 Link to comment Share on other sites More sharing options...
Blair Posted March 15, 2013 Author Report Share Posted March 15, 2013 RickyZ 1 Link to comment Share on other sites More sharing options...
Jim27 Posted March 15, 2013 Report Share Posted March 15, 2013 Interestingly, Nankangs are made by the Yokohama factory and use the older Yokohama tread patterns, just on a slightly harder rubber compound so they last longer. See anything similar here? Link to comment Share on other sites More sharing options...
Marcus Posted March 15, 2013 Report Share Posted March 15, 2013 my van came with Mohawk tyres. which are made by yokohama...best thing I did was wear them out and get them off.which as it happened wasn't long.I run hankook on my car and am happy with them so ive just fitted a full set to the van too Link to comment Share on other sites More sharing options...
e46rob Posted March 15, 2013 Report Share Posted March 15, 2013 Interestingly, Nankangs are made by the Yokohama factory and use the older Yokohama tread patterns, just on a slightly harder rubber compound so they last longer. See anything similar here? :P/> .....that explains why they are good in the dry but a little slippy in wet weather! Overall, not bad at all for the price, just take extra care on wet roads Link to comment Share on other sites More sharing options...
momo Posted March 15, 2013 Report Share Posted March 15, 2013 Fine i'I'll say it - the words "budget" and "BMW" should not be used together.. Its the only thing keeping you and your car on the road. If you can't afford top dollar for Michelin or Pirelli, that's where Veredestein, Toyo, Falken come in.. Just waiting for the day I see someone say they've bought a cheapo budget tyre and then stack it in a hedge! It's a matter of time.. I hope it's not OP. X-Man, sive s, B0B and 2 others 5 Link to comment Share on other sites More sharing options...
RickyZ Posted March 15, 2013 Report Share Posted March 15, 2013 Fine i'I'll say it - the words "budget" and "BMW" should not be used together.. THIS THIS AND THIS, these cars cannot be run on a budget and especially in the 330 you dont want all that power on some s**tty budget. I have had budgets and now have Avons, this qualifies me to comment, spend cheap spend twice Its the only thing keeping you and your car on the road. If you can't afford top dollar for Michelin or Pirelli, that's where Veredestein, Toyo, Falken come in.. Again, I would also add Avon from personal experience Just waiting for the day I see someone say they've bought a cheapo budget tyre and then stack it in a hedge! It's a matter of time.. I hope it's not OP. THIS, I also second Momo and hope its not the OP sive s and momo 2 Link to comment Share on other sites More sharing options...
